Anybody have these for the 265? I believe there's an easy-access spare switched 12V supply in the cabin but I don't know where it's fused, hence the requirement. Thanks, Ben
Yep. Need supply for amp, JL clean sweep and active sub in boot. Understand there's a spare supply in passenger footwell (big double connector plug thing)
Hi mate, I've found a nice handy 80A fused permanent 12V socket completely spare in the passenger footwell!!! Nicely avoids me having to drill through the firewall. Now I need to find an ignition live in the same area...anyone know one easy to tap into (pref without removing glovebox etc again!)
Drill through the firewall :-o there are rubber bungs for that! For a perm, I'd usually recommend taking it straight off the battery with the fuse as close as possible, through a rubber bung. For the switched, split the wire for the switched live on the back of the stereo.
