Hi all Ive recently had the usual window regulator fail on my back passenger window (ive done all the others already) and fitted a new regulator, however the window will only move after pressing the switch 5 times. It doesnt matter if the window is up or down, it will only work when the switch is pressed 5 times and it also doesnt matter which way the switch is pressed (up or down regardless of the direction of travel) Ive posted a video to you tube below Anyone had this issue before? It cant be the motor, and isnt the switch as ive tried swapping this with another window. Is it some sort of programming issue? Or is it likely to just be the regulator and Ive got another dodgy one? Any help much appreciated Graeme
