1. Anyone have a wiring diagram of the ecu.
    I need the throttle position and speed sensor wires.
    Thank you please.
  2. Speed is done via abs iirc
    its all canbus so not just as easy as a pinout.
  3. Thanks for that.
    I can do it with just the speed sensor.
  4. You'll struggle I think.
    what you trying to do?
  5. Connect an hks boost controller. Can set boost parameters to speed or tps?
  6. Found the speed sensor wire now to see which one is the throttle position.
  7. 15 mins with a multi meter and all the wiring is done.
  8. Some pics
  9. Haven't fitted the boost controller yet. The misses is out in it so will get it finished tomorrow.
    It's going under the stereo in this.
  10. Quickly plugged it in to see how it looks.
    Think I will get a console and flock it so I can take the carbon fibre bit out.
    Never liked that part anyway.
  11. I think it's appropriate to post the answer to a question also in case the OP has to come up with it himself, don't you!? ;-)
  12. What question are you on about?
  13. Easy enough to wire in?
    What wires did you use, any chance of a pic of the wiring at the ecu end?
  14. Really easy.
    A1 on the stereo iso is speed sensor.
    I wired direct to the throttle pedal for throttle position.
  15. Nice one cheers for that James, it will come in handy later in the year!
  16. What you got planned?
  17. I'm talking about you figuring out the answer to your own question, but not sharing it ;-)
  18. Oh right, didn't think it would be any use to anyone.
    Don't really see much about boost controllers on here.
    Aidan likes this.
  19. Old post but I’m currently in the process of wiring in my boost controller, I have the speed signal from the radio plug as stated but wondering which wire from the throttle pedal you used? Is it signal 1 or 2? also what about RPM did you use one of the injector wires?
