R26 Dump valve
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Steve r26, Dec 10, 2017.
  1. 542AA39D-AD4F-4E5F-8927-EAF775848F1F.jpeg D65D3572-CB8D-4478-BF7B-E092CBBA054C.jpeg Hi guys,
    I’ve just tried fitting my dump valve, but I’m not sure what this plat is for and the springs, it has to do with something because I can’t really hear the dump valve?
  2. ianplymouth
    If you follow your blue pipe back all the way back to the turbo, you will see the recirculating dump valve, the plate replaces that part
    Steve r26 likes this.
  3. Ok sweet what about the springs what are they for?
  4. ianplymouth
    If the plate is flat and doesn't look like the one fitted then you don't need the spring, the spring might be for the after market one you have fitted
  5. Ok thanks
