Drls on with lights without dimming kit.
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Ovy, Jan 30, 2015.
  1. Ovy
    Ovy
    As title havnt had a look myself yet but surly there's a way to disconnect the feed that kills the drls when the lights are turned on thus leaving them on with the lights? My thinking then would be a mod to switch them off via full lights not side lights so could use rear and dash lighting till too dark for the bright drls. Anyone help with info wiring diagram ect...
  2. Is it me or is that second part after the question mark gobbledegook ?
  3. there's no separate feed that kills drl's.. if the computer is set up to run individual drl's (can also be set up to use main beam), they will turn off when sidelights turn on.. if the computer can be reconfigured to leave them on, I'm not sure..
