Hi all just noticed my right side drl isn't working Got a funny feeling it's not as simple as changing a bulb and it's a new unit or something Has anyone else's just gone
could be LED cluster or ballast Best way is bumper off and swap the led units around to see if the fault follows etc
Good idea that I'll have a look at weekend Not happy that's one of my main loves for the rs looks alot meaner with the drls on I've had to turn them off
Right going to check this Where is the drivers side ballast behind the bumper Is bumper easy to take off as I can't handle living without my drls Hoping it is just the ballast which could well be as aren't led supposed to last a million years
Yeah Off memory X4 10mm underneath X2 t20 in the arch linings each side. X1 10mm bolt under arch lining that bolts to the wing- there should be enough room just to peel back the liner with out moving it fully Few 10mm's under the bonnet I think that it off memory. Then you have to pull the bumper where they clip to the wings which can be a bit daunting You might want to put some kind of dust sheet down as you'll need to keep the bumper on the floor plugged in to test the lamps etc Take some pics for a guide? I was going to do it next time I removed mine Good luck!
