Driveshaft bearing after clutch change.
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Lexy, May 6, 2020.
  1. So after changing the Dmf, clutch, bearing, links,... I reinstalled the driveshafts as normal, everything sits fine accept the plate on the driveshaft bearing mount. Shaft is fully in and bearing is in place. What am I not seeing here? Have the 225 more than 1 year now, puts a smile on my face everytime 4c37373ce7ea71ff0c1b98099a677e4f.jpg
    Verstuurd vanaf mijn MAR-LX1A met Tapatalk
  2. matt e
    what exactly are you asking, what did you want to see?
    Lexy likes this.
  3. ianplymouth
    that's fine, its there to put pressure on the bearing, if it was flat against the bracket, then there would be possibility of the bearing moving/turning.
    Lexy likes this.
  4. Super! Sorry, had not noticed this gap when dissasembling. Thanks a million!
