So today my window has stopped working on drivers side, the switch still works the passenger side though. Also the lock button for the keyless system as stopped working on drivers side. The unlock sensor and electric mirrors are still working. Has anyone had a similar problem or know what it could be? Thanks in advance.
May be water ingress. I'd recommend you look at the wiring block coming out of the door where it picks up with the cars shell behind the carpet/dash down near the footwell. Otherwise check behind the door card. Usually it's the temec module that causes window issues. I'd check the corresponding fuses too....
Where would I find the temec module? Sorry very noob with Renault after owning peugeot for the last 5 years.
