Driver side driveshaft r26
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Dave Smith, Jan 2, 2019.
  1. Anyone know the part number for a 2008 r26 driveshaft, im seeing different sized ones when i look online? Thanks.
  2. Feirny
    Feirny RSM Admin
    8200278603 - OS
    8200278602 - NS
    sunnylunn likes this.
  3. Thanks very much. Does this look right to you?
  4. Feirny
    Feirny RSM Admin
    Outer teething wheel side 27,
    Outer teething differential side 39,
    Length 963 mm,
    Seal diam. 57 mm,
    Wheel Side Joint Ø 84 mm,
    Transmission Side Joint Ø 81 mm, with bearing(s),
    Thread Size M22x1.5,
    Length 2 352 mm, Service exchange part
    That's what info I have, my eyes aren't great so can't really see what your pic says, sorry.
  5. Its not an exact match. Thanks for the info. Ill continue the search!
  6. Feirny
    Feirny RSM Admin
    Where are you based? I might be able to sort one for you.
  7. Im over in Ireland unfortunately. Makes everything harder. Ive found even Renault main dealer stuff is 30% more expensive than in the UK.
  8. Feirny
    Feirny RSM Admin
    Ahh yeah, I'm not much use there then I'm afraid.
  9. Sorry to jump in on your thread, I've been looking for the same driver side driveshaft and have been given a different part number the number I have is
    7711497234
    does anybody know the difference between these to part numbers.
    Cheers Matt
