250 Door removal
Discussion in 'Exterior & Bodywork' started by jack250, Dec 16, 2016.
  1. If I was to take the whole door off the hinges, is there a certain way to refit to get it properly aligned or is it quite simple to put back on?
  2. May I ask why you'd want to do that?
  3. caymanr26
    caymanr26 Events Liason
    As long as you unbolt from the door side of hinge it should just go straight back on - well that's the case with a 225 at least
