door lock on a 225 trophy
Discussion in 'Megane Discussion' started by mapper, May 22, 2015.
  1. hi,
    i have recently purchased a 225 trophy today, i am having a problem with locking the vehicle. i can lock the driver door and boot perfectly but for some reason no matter what i do i cant seem to lock the passenger door.
    any idea what could be wrong ??????
  2. Do you mean from the key/ central locking?? Could be a bad connection between the lock and wires.
    Door card off and have a look at the lock
  3. its key less entry so cant lock it manually with a key.
    is it a difficult job to take the door card off ?
  4. It's tricky at first but there are guides on here to show you. Took me a bit of trial and error at first now I can get a door card off in about 5 mins .
    Worst case scenario is lock has seized and you may need a new unit but check the wires for moisture and if necessary wd40 it
