1. How many door clips do you need to buy if thinking of removing door card? I’ve heard they are likely to break when doing so.
  2. I've had my door card off 3 times within the last 2 months. Not broken a single clip.
    Hardest bit is the handle cover, its weird you need to be careful but without some force your never going to get it off.
    Once all the screws are undone etc then i just start at the bottom, see if you can pull it away abit then once your hands in there just carefully pop the card off. start bottom inside and work your way around the bottom untill the outside. once all popped lift up as its hucked onto the top of the door.
    Number of clips though i think is 5 or 6 in total
  3. Cheers.
