Wing mirror cover pulls of, theres a screw there. Theres 2 x screws along the bottom of the door card, a screw by the doors latch. A screw behind the latch handle behind and cover and one behind the door pull which you have the break (unclip) apart. Then its just held on by clips, which require and trim removel tool similar to a small crow bar, once unclipped the door needs pulling up and off, disconnecting the electrical plugs behind, and cable to door latch handle. If i was you i would get some spare clips as they tend to snap when pulling the door card away.
