So far it's had stage 1 rs tuning map, cat back miltek, itg induction kit (from ktec) wind deflectors (from ktec) , wheel nut covers (from ktec) and black badges when at RS tuning it made 317bhp and 365ft as for cleaning I had auto glym scratch guard but I use autobrite for everything mega foam just a tonic (tar remover) project 32 (sealent ) tyre jell
Looking good mate! Already really strong engines in the 265 in standard form. I see yours did 289bhp standard! Mine did 295! Impressive. I use all autobrite products on mine too (except from the wax) also really good stuff and easy to use
looks very nice, needs megane lettering removing and lowering and that will be even more stunning that already is.
Thanks this year I want do few more bits decat intercooler lowered does the Megane lettering come off easy ?
Looking good so far! Hoping to get my 250 cup to around 300bhp this year with similar mods to yours. Also with removing the MEGANE lettering from the boot, i just poured some tar remover behind the letters, then carefully used a heat gun and some fishing wire behind the lettering to remove them. Came off easy enough for me, and makes it look a lot cleaner i think.
Window tints, double tint sun strip, removed the 'megane' from the boot, CL RC5+ front pads, EBC yellow stuff rears, pipercross panel filter and supersprint race exhaust. Will start a project thread eventually! Think Jamie has a set of h&r springs sitting doing nothing.
I wouldn't of recommended springs on these up until a couple days ago until i removed my coilovers to be sent off to be revalved. On a mates old setup while my coilovers are away, Cup shocks and H&R springs. Not that much stiffer or harsher than the OEM setup but corners much flatter, Looks 100x better and generally gives you a bit more confidence in the car. Can't say if they actually improve handling or not, Would like to get on track and compare lap times but i will be back on my coilovers next time I'm track so won't be able to compare
Thanks Jamie, that does look good. Now go and find some empty b roads for a more in-depth review. Chop chop
I'm afraid that will have to wait roads are bad up here just now, Snow and loads of water. You can see the road in front is pretty much compacted snow and ice at the moment LOL
