Does a forge recirc valve make any sound?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by caymanr26, Aug 7, 2015.
  1. caymanr26
    caymanr26 Events Liason
    As per title? I'm fed up of dump valve sound, fancy a flutter instead so wondering if the recirc would do this?
  2. I have one fitted there is no noise at all. I hated the dump valve and felt a better response on throttle when fitted my recirc valve.
  3. TimR26
    You can hear what the Forge recirc sounds like in my video below.
    [video=youtube;dDkTt7eMivw]https://www.youtube.com/watch?v=dDkTt7eMivw[/video]
  4. A blanking plate makes a chatter noise i think.
  5. Got a forge recirc valve on my 250 makes a slight chattering noise but not loud
  6. Sorry for the stupid question, but with the buy of my Meg I got this plate (not installed from the previous owner)
    http://www.k-tecracing.com/show_product.asp?id=2364&appid=12
    The Engine is 100% stock, no aftermarket BOV or something.
    What exactly can I do konw with this plate ? Or should I not fit it, or if I fit it what are the benefits...
    THANKS !!
  7. Should run that plate with a bov. Some run it without and gives loads of turbo chatter. There's a mix on if it causes turbo damage but upto you.
  8. No sound on recirc
  9. I have a recirc with k-tec induction and it's loud, lovely induction noise then chatter with gear changes. I can drive sensibly and barely here the induction or valve around town but open it up and it comes alive
