250 DIY Induction Kit
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by twistywizard, Sep 1, 2017.
  1. Is there a DIY Induction kit for the 250?
    I have seen a few guides for the 225. But nothing for the 250? From looking at the setup it should not be too hard to replicate the KTEC setup?
    Keen to see what it sounds like without spending £££. A friend has a few cone filters laying around I can borrow.
  2. Ive just used, a joiner, 90 degree bend, and itg cone filter, ram air are cheaper thou. Cost less than £70.
  3. That is the sort of thing I am after. Cone is sorted already.
    Do you have any pictures of the setup and links or sizes of the joiner and pipe?
    Paul21 likes this.
  5. You might find thous links out of date, copy and paste in your browser should get them up, ash 100mm 70mm od joiner, 70mm id 90 degree bend ( think i cut the one side or two a little shorter, and a itg jc60/67 cone filter, 67mm id/70mm od.
    I also made some hook brackets and fitted a spring to take the weight off alittle. Not necessary thou.
  6. Lovely. The first two work and I can find the 3rd no bother!
    Worth a go for the money
