Disc Size
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by john45bryan, Nov 8, 2016.
  1. Whats the biggest disc size you can run under a standard calliper?
    Is it 312mm?
  2. On a 225/R26 that is the standard disc size. You can go to bigger discs but you need to space out the calliper. I think 330mm discs are the common upgrade and are usually two-piece disc and bell. Beware that the discs are expensive in comparison to the OEM 312mm items!
    john45bryan likes this.
