Hey My 225 alarm goes on. I killed one ultra sonic sensor but that’s a year ago and never had trouble but now (it’s very cold and wet) my alarm goes on at random time in the standard the parking spot. i tried it now tho shut off with the press start stop 5 times method and hope it will shut down. but tomorrow I want to deinstall the whole system I don’t need it and cause unnecessary problems. try to google it but found nothing, I know the siren is in the boot left but how I should disable it ?
i had mine deinstalled. if i recall correctly there are only a few bolts/screws holding the siren unit. there is a plug connecting it if not you may just cut the wire and tape it to avoid shorting
Thanks for your answer Would be awesome if it’s really that easy. i will find out later what it does if I just unplug it.
Any joy with this? I want to disconnect mine too, one of the boot sensors has broken off so Alarm always goes off when locked now.
Hey, Yes, as i remember I just throw everything away I found at the boot behind the left taillight. It was mounted on a bracket. You should find it very easy. It’s directly behind the taillight - behind the carpet at the side.
