Differences between 250 cup and 275 trophy?
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by steering, Apr 4, 2016.
  1. Are there any differences regarding suspension and steering components between the two of them?
    A friend of mine just bought a 275 trophy (no ohlins) and told me, it is quite a different car
    Could somenone know or trace any difference (eg. part numbers etc)?
    This article also refers to changes
    http://www.evo.co.uk/renault/megane-275-trophy
  2. Didn't think there was any difference unless you went ohlins tbh. It wouldn't be the first time I saw Evo talk out their arse though about Renaults.
  3. I would like to find this out too.
  4. I've had a 250 FF cup and now in a 275 trophy...
    All mechanicals are the same and drives the same, but 275 seats sit a little higher must be different runners, no extending leg bolster, and a covered steering wheel.
  5. The majority of the differences are cosmetic, the chassis and running gear are pretty much identical.
  6. The ARB is thicker - 24mm in the Trophy. Either 20mm or 22mm in the Cup
  7. I thing you are wrong mate....
  8. Is just a standard Cup chassis. Speed lines will make a bit of a difference because of the unsprung weight reduction but apart from that it was mainly just an engine recalibration and a few little choice bits
  9. Yep - my mistake, the figures were the non-Cup chassis
