250 DECAT
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by nated84, Jun 19, 2016.
  1. Am I right in thinking the DECAT from the R26 will fit the RS250?
    Is the diameter 76mm?
    Just asking as seen one on a site which is cheap and if the specs are the same then ill purchase. Make is Scorpion also.
  2. It should be the same, as i was after a one i asked the same question and the answer was YES.
  3. Cool, thanks for the confirmation, time to order then :smile:
