seen these on ebay https://www.ebay.co.uk/itm/110W-260...fff9a5cc|iid:1&_trksid=p2481888.c100675.m4236 and i was wondering how you would fit them on the megane as the ballast isn't needed. so i guess you would jusst drill a hole in the cover and then wire them in to the loom going in to the headlight? as it uses 1 connector for the dipped/high and indicators doesn't it?
We have used similar bulbs with COB tech fitted to our race car, dipped beam as well as high beam. Immediately illumination, no warm up delays. They are pretty straight forward to install but are not a direct fit due to the size of the heat sink and fans on the rear of the bulbs. However they do work really well but not recommended to be fitted with a normal halogen unit for 'road use'.
