Cutting stainless sheet for induction bracket
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by ChrisC, Jul 8, 2015.
  1. Hi all,
    I've got some stainless steel sheet that's 2mm thick,
    I wanted to cut it down into a bracket to hold my induction kit in place so I don't ruin another filter
    I'm just wondering how others have managed to cut it down into shape?
    I have a set of quite heavy duty snips I've used for cutting sheets of aluminium this sort of thickness, how ever they never really leave a perfect finish as such. And wasn't sure how they would be on stainless steel sheets
    Chris
  2. angle grinder and a thin cutting disc..
    or plasma cutter but its not a everyday diyers item..just sold mine..
    snips will not cut it well or tidy..
  3. As above
    Slitting disc...ie a disc 1mm or less thick
  4. +1 for 1mm cutting disk. Get your self a flapper disk at the same time. they clean up the edges & round the corners much neater than a traditional grinding disk.
    Stainless can be tricky to drill as well, you'll just blunt/burn the bit if your not careful (even with thin stuff) so if you need any bolt holes etc make sure you have a couple of sharp drill bits.
  5. Thanks for your input guys.
    I've got hold of a thin cutting disc so guna try have a bash at it tomorrow
