Hi does anyone know if there is a fuse for the buttons on the steering wheel? When I switch cc or sl on it shows on the dash but the buttons don't do anything when I press them? Cheers Sent from my SM-G930F using Tapatalk
Is your horn still working? It's possible that your clockspring (rotary switch) is broken - common problem!
I had exactly the same issue, including a broken white ribbon which causes air bag light to show up. I bought a complete unit from Renault (£128) and it sorted everything out.
It can be repaired, cost 20£ for ribon cable plus someone whilling to replace it. I do that but im far from you The cable can snapp right off or rub through and make very tiny cracks on the wires. Here is a macro photo of one (the whole ribon is 12mm wide)
