175 DCI Cruise control issue
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Cloudydaze, Nov 7, 2016.
  1. If anyone could help it would be appreciated my cruise control doesn't appear to be working, when I start the car I get an orange symbol on dash briefly but then nothing else no matter what position the switch is in there are no faults on clip other than air conditioning fault which I assume is because there is no gas in the system and when you read info on cruisecontrol/speed limiter on there it says not detecited but that could be because I'm not moving and turned it on brake switches and clutch switch do seemy to work as they go from inactive to active when pressed. it has been mapped and I have read somewhere that there has been issues with some losing cruise feature but I don't know for sure and map was done before I got the car.
    Just realised I probably posted in wrong section sorry
