Correct R26.R DMF number needed pretty please
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by maddog, Feb 6, 2016.
  1. Ive searched but a few different numbers come up.......
    Does anyone know the correct part number for an R26.R Dual Mass Flywheel? Its for my 225 clutch conversion.....
    MD
  2. Hi mate,
    I'd either contact Renault Parts Direct:-
    Telephone: 0844 770 9375
    Fax: 01793 878208
    Email: renaultpartsdirect@gmail.com
    They'll be able to supply, the R26.R clutch, slave and DMF for you - they are usually unbeatable on price also - it will be OEM parts and you'll have piece of mind.
    Other option used for OEM parts is Renault Wolverhampton Parts Dept (We used to have a community member working there and he used to give us great deals - phone and say you are on rsmegane and they will do the same now) - again, they can supply the full works for you - if you want an R26.R registration plate to use to research part numbers pm me.
    Hope this helps. - its what I would do if I was wanting to source the parts.
  3. Renault Wolverhampton number: 01902 439211
  4. Cheers mate. PM sent
  5. matt e
    renault Wolverhampton were cheaper for and also found the bits i needed
