Correct fitment wheel bolts for R26 on OEM alloys
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by andrewjeffs, Feb 21, 2019.
  1. Hey mate!
    Did you find an answer to this question yet? I Just took off the original bolts on a Phase 2 Megane 225 and I could take pictures if it helps. The original bolts have a separate collar for the tapering part; it should help reducing the strain put onto the mating surface on the wheel when tightening.. The bolts with a separate taper collar are bound to be rather expensive to replace though, which is why it would interest me as well if the set on your link would fit instead.
  2. they do fit..i have them on the car now.As you say,no seperate collar,but all seems fine.
    I have had them on and off the car several times,and all seems well.
    PS...will be writing to you tnite...would be doing it now,but the missus hates me typing at speed when shes watching TV!
  3. No worries, mate :smile: And, nice to hear normal bolts work fine. That gives us much more choice, even quality-wise. Thanks for the info!
