225 Coolent Replacement/Flush
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Trophyboy, Oct 6, 2016.
  1. Howdi all
    Need a bit of help with replacing the coolant on my 225.
    Ive recently replaced all the coolant hoses with red ones including a brand new radiator so there is little to no coolant in the system.
    Whats the best way to fully flush the system clean before adding my new coolant and also bleeding the system for air locks?
  2. matt e
    take the thermostat out and fill it up and then just undo the bottom rad pipe to release it
    theres 2 bleed screws one on the side of the thermostat housing and one on the pipe that goes in to a cabin near the brake fluid reservoir
