225 Coolant Temperature Sensor
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by JamesBryan, Oct 20, 2014.
  1. Bit of a daft question as I think i'll know what will happen... But if I change the coolant temp sensor, will coolant come running out as soon as I undo it?
    Guessing it will..?
  2. If it looks like a duck, quacks like a duck & waddles like a duck then it's probably a duck. :smile:
    lee
  3. Should I be alright if i'm quick enough to swap it for a new one? And just top up the coolant level (got 5 litres handy)
  4. The hole is quite big so you will have to be quick. If you leave the header tank cap on it should create a vacuum & keep most of the water in.
    Lee
  5. Yeah, it is a big hole :worried:
    I'm thinking if I top the coolant right up and put the cap back on, then change it over quick.
    Then open the bleed screw to bring the level back down to MAX again.
    Be reet.
