250 Coolant drain
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Ade T, Jan 17, 2017.
  1. Is there a coolant drain plug on the mk3 radiators? Can't seem to locate one. If not what is the best way to drain?
  2. matt e
    is it like the mk2, just remove the bottom radiator hose?
  3. It's a mk3 250
  4. matt e
    yeah i know its a 250! but it might be like the mk2 where you remove the bottom rad hose to drain
  5. Ah sorry I get you... I misread your comment. Looks like a need to pull the bottom hoses then. Thought there may have been a more efficient way to drain it.
