Coolant air bleed valves
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by James and his 250, Oct 24, 2015.
  1. Good morning all,
    Does anyone know where these are in the megane 250? I can only find the one behind the engine and turbo
    Many thanks
  2. Does anyone know? Can only get 2 litres in the bloody thing as its not draining properly
  3. Well the second bleed valve is on the thermostat incase anyone is searching in the future :smile: Left of the battery casing
    Also done my gearbox oil as the car has hit 50K now and that's defiently worth doing. Quite as easy job but you need to get the battery out
