So my scuttle drains were blocked last week and I've sorted all that out. Since then every morning I've been getting into my car to a silly amount of condensation. This morning it had frozen over on the inside. Does anybody know what might be causing this as i don't fancy scrapping ice off the inside every morning. Cheers
Wet carpets ,have you had a look in the floor cubby hole? Mines soaked and causes the inside to freeze up
You may have residual moisture from the blocked drains. Have you checked the carpets / soundproofing foam ?
Ive taken my carpets out while I'm at work, didn't seem too wet, just a bit damp. passenger side cubby hole was fairly wet though. doubt its gonna dry up much in this cold weather!
Do you think you got rid of the residual moisture inside the car ? If not then you'll still get the issue. If you have then there is still a water ingress somewhere
Nah not that i could find anywhere, matts and cubby hole were fine, screen was dry home driving around last night then this morning whole windscreen was frozen over, got no idea where its coming from
Get yourself some of these, i have them in my Clio which is dry inside, no wet carpet or anything but it still mists up. Work wonders! https://www.amazon.co.uk/dp/B00AZZB5UY/?tag=rsmeg-21
I have a similar issue on my 250. Found water in the floor compartment the other day. Dried it out as best I could for now, will pull up the carpet and dry the rest when I get time. I'm unsure where the water got in from though? Checked the scuttle drains but they were fine. (Had this issue on my r26) My only thought is that the drains had frozen over on the cold weather? Any other suggestions??
