Cold limiter
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by david h, Nov 9, 2014.
  1. Well i think my thermostat is on the way out as my temp needle doesnt read straight up, it also seems to run cold at 77f moving and 80f in traffic,
    So i have hit my cold limiter 2 times because of this but after i have caught the cold limiter my engines missfires then clears is that normal?
    i have got a thermostat and coolant on order from renault
    my car is stage 2 with siemens 630cc injectors btw
  2. Yep my old r26 did it, all prone to it. Runs much nicer after thermo and coolant change and mpg should improve
    should run about 89deg when cruising after from memory
  3. Cheers matty did yours missfire too is that normal?
  4. Wont help it but injectors go on the r26s too, get new ones for 160ish or refurbed from liquidf1 for about 100 i think
  5. Ok cheers , my injectors are new
  6. Just change the thermostat David , I hit cold limiter once by accident in my old R26, misfired after
  7. Ok cheers steve, i have one on order ,its just the missfire that worried me cheers guys
