Code 789 flywheel adaptation
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Sammy_2007, Sep 16, 2013.
  1. Hi people on my search to find out why my car is down on power I had it plugged in today at work and it came up with code 789 flywheel adaptation fulty sensor what sensor could it be o what could this problem be if anyone has a clue?
  2. Do you have a smf? I would say crankshaft sensor as thats the only one that reads the trigger pattern on the flywheel
  3. I do have a small one on idle but its fine under load. Can it cause loss of power eg boost
  4. I mean single mass flywheel,
