265 Clutch pipe
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by James265trophy, Feb 17, 2018.
  1. Has anyone changed their clutch pipe themselves or is it a garage job? Mine is leaking and stripping the paint off the antiroll bar.
  2. I did mine. Ballacre getting to it and an even bigger one bleeding the system! Took me best part of a full day but it’s first time I’ve ever done one.
    My advise would be take it to a garage. The part itself is £80 from Renault then probably 2-2.5 hours labour. Should be no more then £200 all in.
  3. Cheers for the reply, did you use any special tools? And how much Blake fluid did you use?
  4. No special tools just lots of scrapes knuckles and patience! I used around a litre.
  5. Nice one, got 2 litres so should be more than enough!
  6. ianplymouth
    If the peddle doesn't feel great after, wedge the clutch peddle down with something and leave for an hour or more, then release the peddle slowly
  7. Will do, cheers.
