Clutch noise
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Andy265, Jul 27, 2014.
  1. Hi,
    Looking for a bit of advice. Was driving the megane today. As I went to set of on a hill start there was a strange noise from the clutch! Like a whining noise.
    Any ideas?did it a few times after but not since?
    Cheers guys.
  2. It generally means you arent going fast enough or revving it hard enough.
    If you can hear the clutch then you are not driving the car the correct way. The correct way is flat out.
  3. ( release bearing most likely. I bet it only did it when you had just released the pedal )
  4. How many kilómeters have your car?
  5. I have a RS 250 Cup with 17000 kilómeters, i dont have change my cluth yet.. But i purchase just in case. Only i need the hidraulic crapodine. This latte is the same like Renault Master 3ebumeju.jpg tazudyna.jpg 6avequvy.jpg
  6. Yeah it was when I came off the pedal.
    Car has done 14k miles. I only got it last sat.
    Should I book it in a Renault?
  7. my R26 squeaks , but thats the pedal.
    I strongly suspect its release bearing especially as you stated it was when you released the pedal.
  8. Isn't necesary yet. I think, supports much the original. I have just in case. Try to bleed The hidraulic circuit of pedal and try..
