Clutch Master and slave locations? 225
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by maddog, Feb 5, 2016.
  1. Can anyone point me in the direction of where my clutch master cylinder is??? Do i need to remove stuff to get to it?
    Also, how do i get to the bleed nipple for the clutch? Is it visable from above/underneath? Do i need to remove stuff to get to it?
  2. Master cylinder is at the clutch pedal, bleed nipple is on top of the slace cylinder
  3. where do you top up the clutch fluid then?? Ive had a look by the pedal and cant see anything obvious?
  4. It takes it from the brake fluid reservoir. They both use the same fluid and reservoir. So just top up your brake fluid.
  5. lol i bloody love the french!!!! So if theres air in the clutch theres air in the brakes?!?!
