250 Clunking sound
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by jack250, Aug 19, 2016.
  1. Getting a bit of a clunking sound over uneven ground, as if something is lose front left. Ball joints already replaced few months back. Track rod maybe?
  2. Track rod ends can do that also, at least mine did it a little before new ones.
    Sent from my SM-A300F using Tapatalk
  3. Did replacing the track rod ends sort the problem out s4bit? Did you replace anything else at the same time?
  4. Anti roll bar end links can also cause clunking sounds...
  5. Best option is jacking the car up and having a poke around to see what's lose?
  6. I cant tell you that its 100% gone but it is much better. Changed front pads at the same time but it doesnt matter. And for jacking up the car, some things can be found only when the car is on the ground.
  7. I have a clonk too - hoping this is what's causing it as it'd be a very cheap and easy fix!
  8. track rod or anti twist rod both make clonk on uneven surface
    neilrs likes this.
  9. Got this fixed and it was
    O.F drop link £18.68plus vat.
    N.S Anti rotation rod £57.62plus vat.
    Took the garage 1.5 hrs to find the cause but got there and now the car is like new :smile:
