265 Clip help
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by DextAir, May 18, 2015.
  1. Hi All,
    I would like to do a compression test on my Rs265 and the repair manual says:
    Run commands using the diagnostic tool - RZ003 and - VP036 before test it with the compression gauge.
    So, how can I run these command from can clip v147?
  2. I wouldn't worry about it. Just do a compression check as normal with food on accelerate pedal
  3. -Jamie-
    As above, When mine was checked we just done it the normal way
  4. Why are you doing a compression test?
  5. welcome along Frimley, how you adjusting ??
    back to OP, for ref. a leakdown test more revealing than simple compression test
  6. Thanks. I just got the car used and would like to check as i have a gauge. Just interested :smile: How to do leakdown test?
