R26 Climate Control not switching fan on
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by xstian, May 31, 2017.
  1. The climate control won't switch the fan on, even if you set the temp at the lowest or highest temp.
    If I use the controls manually the fan works fine on all speeds.
    Any ideas what it could be?
    Christian.
  2. is the air con full on gas?
    do you have climate or standard air con for the poor?
    if it is empty the pressure switch will detect a low pressure so to save the compressor from damage, it will disables the air con function kind of things on the climate control
  3. sorry didn't read the title very well like i said above it applies
  4. I have Climate control fitted. In manual mode the everything works fine inc. the AC. But when I switch it to auto The blower/interior fan doesn't come on. If you put your hand on the vent I can feel the cold AC air coming through, but not by the fan. This is the same for hot or cold.
    On auto mode the picture of the fan disappears, is that normal?
  5. I just thought I would update this. The climate control has suddenly kicked into life again, so hopefully all is well, for the time being.
    Thanks for the help.
