R26 Clicking on lock - CV joint?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by idontknow, May 8, 2018.
  1. pervertedmonk likes this.
  2. i had this issue before. mechanic found out it was caused by a faulty steering push rod end. changed that and it is now fine.
  3. Sorry just seen this but thanks for the reply. Replaced Offside driveshaft and all is good as it was the CV after all
    Just need to replace the parcel shelf then it will be a completely new car :-)
  4. Did you buy the shaft from the above?. I take it they were ok to deal with?.
    Sent from my SM-A520F using Tapatalk
  5. I've just ordered an o/s driveshaft off them today. Says delivery Monday. Will post the outcome. Same good price at 90 odd quid.
  6. had mine delivered as promised. all branded boxed as well.
  7. Was the replacement straight forward? I've got the jest of it but did you come across any problems?. I ha e a new seal to replace too. Did you use a new hub nut?.
