Check Injector now it doesn't start
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Marc Hanson, Mar 29, 2019.
  1. Hi guys I have joined in the hope of gaining some knowledge from you lot out there! My car cut on me today and gave me a check Injector warning and now wont start. Anybody no what it could be?
    Any help is appreciated, going out of my mind with it
  2. ianplymouth
    try the crank position sensor
  3. How?
  4. ianplymouth
    The crankshaft position is not only for the ignition timing it is also used for the injectors, How, just replace it, if it makes no difference then keep it as a spare as one day you will need it, but if it wont start that's where i would start.
    If you turn the ignition on but don't start it can you here the fuel pump kick in ????
  5. I had "Check injection system" warning. P0335 error code
    Found out that the crankshaft position/pulse sensor is faulty. It was damaged by the blown up slave cylinder
    Daryl Lim likes this.
  6. I think so but I would have to double check to be sure. Thanks for your advice, I'll start with this deffo
