Check Injection System
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Daryl Lim, Mar 7, 2020.
  1. Hey,
    My cup265 shows "Check Injection System" when is at high gear 5th or 6th during cruising. And I've to clear fault code everytime. What's wrong with this?
  2. could be oxygen sensor on zorst at they're most used at cruise speed and not during acceleration
  3. 7E91C558-E45A-40DB-925C-10F1578CF12F.jpeg This is the fault code: DTC226321.
    Something to do with mapping?
  4. So you have checked all the different sensors?
  5. ianplymouth
    I have the second fault on that list, also have a few other faults as well.
    If you find a solution let us know, mines in limp mode and i cant get it sorted atm.
    also got engine speed sensor, motorised throttle unit, also some computers not entering dialogue and key not recognised :cry::cry: :cry:
  6. ianplymouth
    and mine is on a factory map
  7. Yes all sensors all doing good. No issues with all the sensors
