Check Injection codes and CC/SL not working
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Jall, May 31, 2023.
  1. Any RS gurus able to help with the below?
    Car: Facelift 265, ~73k/kms
    Symptoms: Spanner light on dash, check injection system error, check cruise control/speedlimiter.
    Codes present:
    DTC023A Charge Air Cooler Pump Control Open Circuit,
    DTC1525 / DF1012 Multiplex signal need to Cruise Control.
    I have replaced the auxillary electric water pump and code still present. Checked all fuses for continuity. Not sure what else would be in this circuit that I need to fault find. I assume the CC/SL has been disabled due to the presence of the waterpump code but not sure...
    Also, the AC has stopped working, but that's probably unrelated. What a car. :tearsofjoy:
  2. Oh, it also has a brand new battery. :smile:
  3. did you ever find out what caused this?
