Hi Im having problem with 2011 megane rs 250. I got error message check injection and everything still works totally normal I check error codes with clip and it have code what relate to intake camshaft. Code was dtc001662 I change that sensor with oem part and error still on. If i erase codes it disappear for like 30sec. Could it be crank sensor even the code is about cam sensor. Sry for bad english im from finland Any ideas?
Did you ever resolve this? I have the same issue. Used to be able to clear the code and it wouldn’t do it for ages, but now it returns each time I clear the check engine light and restart the car. Thanks
Yes i have solved this. Timing was wrong because cam gear was broken. Mechanic who change timing belt probably didnt tighten the cam gear bolt properly atleast i think so. Shop pay the repair for warranty.
