Check i am ordering the right bits
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Mikeyjp, Mar 4, 2017.
  1. Hello
    I have got a Megane 250, after some reading on here i want to sort out the gear box mounts and engine mounts, to stiffen things up a bit. Just want to check with you guys i have got my head around what i need
    So i am looking at ordering the Meg 275 gearbox mount, M12 bolt, 2x Vibratecnics mounts and a yellow upper engine mount insert
    sound about right? anything else? dont want to go crazy, needs to be a daily driver
    thanks
  2. -Jamie-
    Why 2 Vibratechnics mount? You only need one
  3. ah my bad, i thought i read somewhere there was an upper and lower one, anything else you would recommend sorting like that?
  4. -Jamie-
    Vibratechnics lower dogbone, Revised gearbox mount and maybe a Yellow insert for the main engine mount is plenty.
    Mikeyjp likes this.
  5. What does changing the gearbox and engine mounts do exactly?
  6. Reduces the movement of the engine,not needed for street but better for track , I have the Powerflex black insert , M12 bolt and the Vibratechnics lower dogbone , a little vibration but not disturbing..
    RS250 likes this.
