Hi Guys! I need help: i need a some Chassis number of Meg RS Trophy to ask about grille front leds. I have a Megane RS 250 But i would like order Long leds yo my car. Thanks in advance! William
Look at the LEDs on the white meg posted above. They are definitely longer than the (normal) 250 ones
I'm Comfuse, i Want the longer leds.. Which ones i need? RS 250, RS265 or RS Trophy. My car is RS 250 Cup.
The longer 265 LED's won't fit in the RS250 front blade, the 265 LED's also have different wiring looms and LED drivers.
You can't simply swap the grill/blade and add the longer LED's, they will not work as the power supply from the LED drivers is different as is the wiring loom.
Hi, i didn't know that . Is possible that you give me a more information about wires and conections? Thanks a lot!
The 250's DRL units consist of 3 LED in total they are driven by the OEM power supply with 6.5W of current. The 265 on the other hand comes with 6 LED's per unit which means the current will be around 12W meaning you will need to fit the power supply unit and wiring looms from a 265.
