275 Changing second lambda sensor
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by TheHood, Feb 9, 2024.
  1. The post-cat lambda sensor on my MK3 needs changing. Just wanted to check if the easiest way is from above as per the service manual, or can you get to it from below?
  2. ianplymouth
    definitely from underneath
  3. Can't say I'm keen on crawling around on the floor but if it saves a ton of time I'll do it that way.
    I really miss the pit my brother-in-law had in his old garage :coldsweat::grinning:
  4. ianplymouth
    I do it all the time, two jacks, one either side and a pair of axle stands :sunglasses:
