changing Rs monitor units.
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by odinson, May 27, 2015.
  1. As above can the units on the rs monitor be changes ie bar to psi, nm to lbs?
  2. Yes they can but only via clip.
  3. Whats clip?
  4. I would also be interested in doing this
  5. Renault diagnostics.
  6. Ahh sweet ok I'll have to find someone local with one thanks
  7. -Jamie-
    Im getting my retrofitted one changed at some point, As it reads everything in metric
  8. Only trouble is power etc is useless after your mapped
  9. -Jamie-
    TBh its a bit of a gimmick, Ive went nearly 3 years of ownership before retrofitting mine.
    Ill be getting some proper gauges fitted eventually as i don't trust them 100% anyway
  10. I've wondered how accurate they actually are but the only one I really use is the one with intake temp and oil Temps but again not sure how accurate they actually are
  11. Hey Jamie! How did you retrofit the RS monitor? This is like the best guarded secret on the forum - what parts needed changed / what needed reporgrammed / etc etc! :-)
  12. Before I discovered RS monitor in my RS I found one forum where guy fit it to Twingo RS or something simillar:smile: I think it's most probably just screen + Clip.
  13. You got a part number for the correct screen?
  14. I can check later in Dialogys.
