250 Changing injectors
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Charlie Howard, Jul 17, 2019.
  1. Charlie Howard
    Does anyone have a guide on changing the injectors in the 250?
  2. matt e
    disconnect the fuel line
    undo bolts holding the rail to the inlet
    unclip the injectors from the rail
    refitting you might need a small amount of grease on the o rings to get them back on the rail
  3. Charlie Howard
    Sounds pretty easy, easy job? Did it on my 225 and 182 what's it like compared to them?
  4. matt e
    will be the same, the injector clips on the mk3 are easier to remove as well
  5. Charlie Howard
    Ah okay cool, cheers!
    Do you know who makes the genuine injectors? They're 60 a pop with RPD so was going to see if I can get them cheaper
  6. Charlie Howard
    They definitely the genuine ones? I've heard that they weren't Bosch
  7. can ask why changing injectors ??
