225 cars gone into limp home mode
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Besty77, Apr 28, 2015.
  1. Driving home from work today my 225 started running lumpy, I got check ignition, esp and emissions messages flash up. It wont rev and the exhaust is pulsing as though its only a couple of cylinders running. I'm no mechanic but is there anything I can check/do before getting a mechanic out? Any help would be appreciated
  2. When were you spark plugs changed last?
    and....
    Have you had your injectors cleaned recently? If not that's a starter, if that doesn't help then my next stop would be to check/replace the coils. Best to get your fault codes read via OBDII port reader or CLIP if you can.
  3. Hi thanks for the reply, turned out to be 2 of the coils. Got them all replaced. Cheers
